I know what you're thinking, not another project that wont get finished for years LOL.
This one has been easy enough, working on it inbetween other projects.
I decided to go a bit Ausie mine spec on this and add some fire suppression units, air con and a walkway surrounding the cab with access ladder.
It's still a work in progress but here it is so far.
Original URL: http://i26.photobucket.com/albums/c143/wi1482/12398714_10153401580702956_1527030938_o.jpg
Original URL: http://i26.photobucket.com/albums/c143/wi1482/735011_10153401863142956_3000216211337399147_n.jpg
Aircon unit, just a rough paint on this, still need to paint it and stick it on.
Original URL: http://i26.photobucket.com/albums/c143/wi1482/12366239_10153401584412956_5136816789683724168_n.jpg
And the walkway, rough at the mo, stuck on with blue tack to get some fitting ideas. Have done the access ladder for the other side, just need to figure out on how to hinge it.
Original URL: http://i26.photobucket.com/albums/c143/wi1482/12366354_10153404394747956_8913185992975520851_n.jpg
Original URL: http://i26.photobucket.com/albums/c143/wi1482/10489966_10153404394717956_2728374067022980765_n.jpg
I'll post some more photos as it comes along.
Komatsu D475 project.
Topic author - Posts: 604
- Real name: Martin Williams
- Has thanked: 9 times
- Been thanked: 43 times
Re: Komatsu D475 project.
Nearly finished.
Handrails painted and walkways on, just need to add a small set of steps each side to access the higher rear walkway and he outer handrails.
Paint match was pretty much bang on!
Original URL: http://i26.photobucket.com/albums/c143/wi1482/12510900_10153444771792956_818960289_o.jpg
Original URL: http://i26.photobucket.com/albums/c143/wi1482/12546126_10153444772282956_80182620_o.jpg
Original URL: http://i26.photobucket.com/albums/c143/wi1482/12528236_10153444771307956_85633394_o.jpg
- Has thanked: 1876 times
- Been thanked: 1693 times
Thanks lads,
Dave, the ladder was cut off a JOAL Komatsu WA800 and I added some brass handrails to it. The rest of the handrails are brass.
