Hello again ,
Thanks for your interest, I'll try to cover a few more of the 1950's rope machines I worked on.
I worked for a firm in the early 60's who ran older Rustons, Priestman Tigers, a Smith and a Blaw Knox 50.
End of the 50s Priestmans producd the Cub 1/4 yard, Wolf 3/8 yard, Tiger 5/8 yard,the 3/4 yard Panther and the new model the Lion was a 7/8 yard machine.
Appart from the Cub which was available with various Lister and Ford Engine options all the ones I worked on were Dorman powered. Priestmans inroduced the Hydra Cub backactor about that time with a ram to crowd and empty the bucket, and air control on the new Lion though I didnt get to work on them for a few more years. The only one I never worked on was the Wolf though I did transplant the 3 cyl Dorman from a retired Wolf into a 72T roller.
The two tigers we had were fairly new and very reliable, only ever did servicing and clutch and brake bands on them.
The Rustons were 19 and 22 RB's dating from 1937 to brand new. The 1930s 19's had 3VQR air start engines,there was a 2 cyl. petrol compressor unit on the floor behind the drivers seat (or should I say saddle)
one cylinder driving and the other making air. The opperator had to kneel to swing the compressor. If the system was sound you could build 350 lbs. pressure and that would start the engine every day for a week.
One unusual feature of these engines was a three peice con-rod, the rod consisted of top and bottom caps and separate rod with the bolts going through all three, you had to introduce shimms between the top cap and rod to get the correct bump clearance between the piston and head. (Better than the Perkins P & R series of that time where unbeleivably to fit new pistons you had to build them in then measure the clearance across the top of the block ,take them back out, remove the con-rods, turn down the piston crowns in the lathe and assemble it all again. You might take off anything from 0 to 60 thou and they'd all be different).
I grafted a Gardner 5LW out of an Albion bus into one of those 19's. The19 was 27 years old at the time, it was on face shovel and first job with the new heart was to load 30,000 tons of ballast. Went without a hitch.
On another occasion a newer 19 RB (again on face shovel) which was fitted with a Ruston 4VROH engine, was sited in a hole being fed by dumpers. He was feeding a coal washing plant and the whole opperation depended on this machine. There was no means of getting a dead machine out of this hole.
I was sitting in the workshop building up the teeth on a bevel gear for another Ruston, ( we did things like that in those days), when Bill, my boss, came in and announced that the 19 had broken its crank shaft.
The opperator, looking at what I was doing said sarcasticly," It's a wonder you dont want to weld it isn't it?"
"Now thats an idea!!"says Bill. "Fffred?"
The engine had crank case doors (plates) on the sides, so I was able to get at the crank. It had broken through the web between 3 and 4 . We dropped the oil and alligned the break, I gouged it out pretty deep and welded it using a chrome dissimular rod.
Beleive it or not we were able to drive it out of the hole with the assistance of a 955 pushing at the counterweight and ran long enough to get it back home. We found another Ruston engine to put into this one.
Lots more to say about it all but I'd better post some photos and go to bed.
The way we were
Topic author - Posts: 2358
Re: The way we were
- Real name: Dave
- Has thanked: 57 times
- Been thanked: 5 times
Re: The way we were
great photos and reminiscences there Fred
look forward to the next instalment
dave
dave
- Real name: Steve
- Has thanked: 1248 times
- Been thanked: 1834 times
Re: The way we were
Great topic Fred
I've been onto someone on one of the truck forums that has some appropriate pics and asked if he could post them here
Steve
Steve
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Re: The way we were
Neversweat wrote:Great topic Fred
Steve
Yes Steve , the more the better.
I asked in the first post if anyone had photos of larger Ransomes & Rapier Machines, I have a few more here.
And one to remind us what the job was realy like.
