Caterpillar high drive side boom
Topic author - Posts: 19
- Real name: mick
- Been thanked: 7 times
you dont see many cat 583t
- Real name: Ian Fletcher
- Has thanked: 534 times
- Been thanked: 148 times
Re: Caterpillar high drive side boom
Hi Mick - Thanks for posting - is this unit based in the UK?
Ian
Ian
- Real name: mick
certainly is. in northwich,supposed too be the only one in the country
- Real name: mick
some older ones
- Real name: Stu Bickley
- Has thanked: 70 times
- Been thanked: 116 times
Its based on a D8T powertrain, few differences to track frame and chassis.
SB
SB
Thank you Kas, very interesting shots... The '8' of the 583 denotes the model, usually, although the 571 was a four cylinder machine and the 572 was a six, go figure. The newer direct start 583's were rated at 50 ton, I remember driving a brand new one in Scotland for Turriff and LLoyds testing (I think) came out on site to calibrate it or some such thing, they had a 50 ton test weight and I had to lift it - initially no chance, first the clutch slipped and I had to dog that up, then when it was a couple of feet in the air I had to hold it, the hoist brake wouldn't hold so I had to dog that up as well, eventually it would lift the and hold the 50 ton load (the boom was up against the back stops, springs metal bound) and then they tested it at various radius es with reduced weights and then gave it a clean bill of health. By the time they departed the machine was virtually undrivable, neither the hook or the boom would free fall and it required super human strength to get the clutch to toggle - it was hours before I got it back to how I liked it! I would imagine that the one you photographed would be a hydra boom as they were coming in when I last worked on a pipeline. Press had a dose of 22A's hydra booms, they also had a dose of BTD 20's but they had cross dog Boughton draw works!
Hi, I drove the 83T in the pictures 2yr ago in Bathgate when it was on hire to land + marine from Laing o'rourke (select) but worked with it when it was new the previous year at selby ! Last tear I had a 589 in Belgium which was 12month old if I can work out how to post pics from my phone I will show you the old girl. It was a pleasure to drive with plenty of grunt
- Real name: clive gray
- Has thanked: 174 times
- Been thanked: 242 times
A bitch to load and carry on the low loader kazmik I bet. A bit one sided?
