Street scenes
Discuss equipment which does not fit in in the other forums here, like cable cranes, material handlers, drilling, piling and screen equipment
Has thanked: 477 times
Been thanked: 297 times
Re: Street scenes
Post #81 by essexpete » Mon Jan 05, 2015 10:34 pm
tim wrote:
Neversweat wrote:
essexpete wrote:So how do you tell a Reiver from a Mastiff (not a riddle :D )
Spelt differently :D :oops:
Visually the Reiver has the air cleaner behind the cab and fuel tank on the offside.The Super Mastiff has the header tank behind the cab off side and the fuel tank nearside.
I knew someone would have it!
The other Mastiff trait was its tendency to bounce and hop when shunting with the engine hunting, at least the one on the farm where I worked was like that.
Has thanked: 1008 times
Been thanked: 905 times
Re: Street scenes
Post #82 by FOWLER MAN » Tue Jan 06, 2015 7:49 pm
Yes Pete,
A problem usually caused when the engine mountings got soft and need replacing.
One end of the throttle linkage attatched to the fixed chasis / frame and the other to the governor which moves with the engine opperating the throttle involintarily.
I got over the problem more than once in some of the older lorries by rigging a throttle cable instead of a rod. This takes the kangaroo out of the tank instantly.
It was more of a problem with the old vacum governors with a butterfly in the manifold which seemed to be more sensitive to engine movement. the first one I converted to cable was an old 1957 Kew Dodge, (Hell Drivers Type), with a vac. governed Perkins R6.
Cx5
Real name: Michael
Has thanked: 9 times
Been thanked: 78 times
Re: Street scenes
Post #83 by Cx5 » Thu May 26, 2016 12:24 pm
A Cat sitting on the former forecourt of the Heron/Texaco service station at the junction of the B660 with the A1 in Huntingdonshire.
The demolition of the Wimpy/Happy Eater was about to follow on as this was the beginning of the A1 upgrade between Alconbury and Peterborough which commenced in April 96 and was completed in 1998 at a cost of £128 million.
More details http://webarchive.nationalarchives.gov.uk/20120810121037/http://www.highways.gov.uk/roads/projects/4442.aspx
