I'm a bit of an anorak when it comes to collecting models of vehicles I've owned and I would like them to have the correct number plates. Does anyone know if there is a website that allows you to print scale number plates with your reg no. on?
What I'm thinking is 'Select Country-Select Scale-Type Number-Press Print' kind of thing but there doesn't seem to be any.
How I'm doing it is using a Seiko label printer and the 'Franklin Gothic Demi' font in size 10 and arranged ZZ 88 ZZZ or ZZspace88spacespaceZZZ. This to me is sort of passable for 1/24 scale but not brilliant.
I have downloaded the correct 'Charles Wright New' font but for some reason my printer won't accept it. Also it won't go below size 8 font so i'm stuffed for 1/32 or smaller.
Any tips or tricks for getting this right and going down to 1/32 or 1/43 scale?
Any help appreciated.
UK no. plates
- Has thanked: 1880 times
- Been thanked: 1695 times
Re: UK no. plates
Rob I think that perhaps looking on a modelling forum you may get some tips? Just an idea
- Real name: Tony
- Has thanked: 45 times
- Been thanked: 48 times
Re: UK no. plates
If you can print out the correctly proportioned layouts on your own printer at the smallest size for quality, then pop into a print shop and for the cost of one print reduce it down to required size on a decent photocopier, you should get the right size at the quality you're after? And printed on card too?
Topic author - Posts: 997
- Real name: Rob
- Has thanked: 199 times
- Been thanked: 281 times
Re: UK no. plates
Thanks guys, yes the modelling forums are well worth a look. Ah, er... wrong sort of modelling. Ahem.
To get the correct proportions (back to number plates!), I did think about taking a picture of the actual plate and re-sizing it but to get it to print anywhere close looks like it could be more luck than judgement.
Still early days, I'll let you know how I get on.
- Real name: Rob
Re: UK no. plates
Managed to 'borrow' a Dymo self adhesive label printer from work, and after a little experimentation printing XXNNdoublespaceXXX in 10pt appears to be quite passable for 1/24 scale UK plates. The tapes are available in black print on white and black print on yellow so all I need to do now is investigate it's use for other scales.
