I am at a verge of setting up my stockpiling outfit for sand.
I intend to make a small start-up then expand gradually. I will start with just a loader and probably hire a couple of 20tons dump trucks locally.
From my preliminary calculations using a wet factor of 2.08, I have about 78,000Metric tons of sand to pack and stock pile 15Km away from the river. From my 3 years research, this exercise will be done when the river is completely dry and accessible to the proposed heavy equipment.
My main challenge is to be able to identify a suitable wheel loader (in terms of type, model, capacity and lists of often replaceable parts) that I can purchase to fit my current requirement? I am bias on CAT products for obvious reasons as availability of service/maintenance experts and spare parts.
Can someone please offer a word or two on the above challenge?
Many thanks.
Danny
Wheel Loader - Right Choice????
Re: Wheel Loader - Right Choice????
Perhaps a lease arrangement on the machine would be the best option. as part of the deal you may/ will get a maintenance / breakdown cover within that contract. Second hand machines can be good, but could also be a money pit.New machines are pretty expensive to purchace out right and depteciate.
Hire a machine that could do the job, hire companies then would look after maintenance and breakdowns.
Cat gear is good but expensive try other companies. Chepstow plant have a few good used loaders including Cat equipment.
Perhaps a demo machine would be an option ? I would check up on a few companies on what they can offer , shop around.
Good luck
Good luck
Will the shovel be working in the stock pile yard only, ?..Where in the world are you
- Real name: Jim
- Has thanked: 5 times
- Been thanked: 20 times
A local company uses a fleet of new & old Volvos for their sand & gravel operations.They have pits around this rural region & stockpile it in a location in town.
A couple of other locals use Volvos too.
I'm impressed by one bloke who uses a Volvo loader with 4in1 & rippers to dig dams.The ground here is tight clay & the loader does a good job in good time.Most dams here are sunk by dozer or excavator,so it's good to see this loader at work.
Jim
Jim
- Real name: jack
- Has thanked: 25 times
- Been thanked: 7 times
as kwdldk asks will the machine be used in the stock yard to out load only or will it be used to both inload and outload. eg, 78000 tonnes out @ 20 tonne a time over 12 months on a 5 day week is 15 loads per day.so if its in and out then double,or any combination.a decent used Volvo,cat,komatsu are the premier choices and then jcb,hyundai or Doosan. as you don't specify how quikly the sand needs moving and how big the margin of profit,or wether the job is one off or continuing these calculations are for a 12 month period,(estimated not calculated).regards,jack preston.
Great.. First of all I wish you all the best for your business. I would like you to suggest please design your website and publish it online. So that your business would grow 50% more.
