Gainsborough Marshall
Topic author - Posts: 4075
- Been thanked: 690 times
Has anyone seen one of these. Looking on the net only 150 were built. Coming from the late 50s they must have been huge. I wonder from the photos if they were all wheel steer? Apparently Leyland 680 coupled with a multi speed epicyclic transmission.
Re: Gainsborough Marshall
Hi Pete,
Here's a leaflet and some pics I took of Andrew Beulah's Gainsborough a few years back.
A local company used one for a while for loading coal and I actually bid on one at a Ministry Sale at Church Down, Glos. Perhaps its as well I didn't get it.
Apparently from what I'm told, for some reason, the hydraulics were driven from an intermediary shaft in the transmission. This caused the pump speed to vary with the gearing taking away the hydraulic power when needed most.
They were rear wheel steer.
A couple of Gainsborough Tractors at work on airfield construction with 8 yard Onions boxes.
Armoured Gainsborough's at the works.
Thanks Fred. The photo I posted above the front wheel looks turned slightly. Must be an illusion. I guess the hydraulic issue could have been sorted by mounting a pump drive on the engine. They must have had some poke to pull the onions.
- Has thanked: 1876 times
- Been thanked: 1694 times
Thanks Fred Pete as you can see in one of the photos, there is one owned by Andrew Beaulah, he brings it out on most of his working events.
