Worked the machine for around four hours in hard ground,went well only fault was a leaking low pressure return hose on valve block.
Pictures show machine levelling the land around the stables
125 DROTT WORKOUT
Topic author - Posts: 6393
Re: 125 DROTT WORKOUT
125 at rest after its workout. This part of the job is nearly done.Only problems have been a battery earth strap and a minor hydraulic leak. Once this task is complete the machine will be loading a few hundred ton of stone into a dumper then fill in the area with the spoil dug out from the first job.Enjoyed the workout with the 125.
