New file available for download!
Visit the downloadarea and check it out.
Please rate it if you download the document!
Description:
Perkins New 1000 Series Workshop Manual
Models AJ to AS and YG to YK
4 and 6 cylinder diesel engines for industrial and agricultural applications
File: perkins_new-1000-series_shopmanual_sec_wat.pdf
"Perkins New 1000 Series Workshop Manual"
Topic about download "Perkins New 1000 Series Workshop Manual"
- Real name: mike medina
Re: Topic about download
where can i find the old workshop manual version for perkins 1000 series? i need to set some parameters to my deepsea.
Thanks for this very helpfull.just had a massey 6480 with this engine it had very low oil pressure 0.5bar at idle and 2bar at full revs its done less than 4000hrs.took the sump off and one of the piston cooling jets had come off so a nice easy fix.and before that a mc-cormack mc135 with the same engine it was leaking coolant from between the timing case and block.
bornfree
bornfree
