Oshkosh R-series
Topic author - Posts: 56
- Real name: kevin ronan
Oshkosh R-series
Scans from a 1971 brochure
Re: Oshkosh R-series
Same here. The old-old one I ran was pretty beat-up when I got to it. But, it never failed me.
If the 1693T CAT motor was one of the power options, you could (theoretically) fit a V-12 Detroit in there. The length of these two engines were about the same. From the size of the radiator grille, cooling the later probably wouldn't have been a problem if a slightly larger radiator was installed. The 1693T Cat was rated at 325 hp, the 1693TA was either 375 or 425 hp. Get's one thinking.....
- Real name: Wouter
- Been thanked: 27 times
WANTED Oshkosh R-series information
On the DHS forum I recently found the photo and quote listed below and because all the positive reactions I recieved from fellow Caterpillar and Oshkosh scale models collectors I contacted Dan Models to see if its possible to make this unique Oshkosh R series truck in 1:50th scale.
Dan Silvestru is excited as I'm, but we need more information, dimensions, drawings, specsheets and photos, photos and more photos to even start with this project.
If you are in the possession of more photos or additional background information like Drawings, Specsheets or Brochures about the 1:1 Oshkosh R series truck I would be happy if you send your response to info@minimovers.nl
Only with your help we can make this project a succes!
This giant Caterpillar powered Oshkosh R series, was one of a number that were sold to the Saudi Arabian Bin Laden Construction company in the late 1960's.
They were 6x4 drive with plantetary axles, fitted wth sand tyres and Hyster supplied the heavy duty flat bed. This example was one of a few that were also shipped as a package with the mighty Caterpillar D9G dozer on the back. It's pictured outside the Caterpillar dealer in Wiscsonsin where it was later shipped to the Gulf.
Not many rigid trucks of the day could transport such a load and these did it with ease. These were the largest trucks Oshkosh had produced until the arrival of the even larger J series which came out in the 1970's.
