Found this interesting, pity there is not a commentary :https://www.youtube.com/watch?v=EEY2lx5ALxY
The Atkinson (Gauardsman I believe) was a bit modern looking for Atkinson!
The Leyland Ergomatic cab must have seen must have seemed revolutionary when you think the Ford stand still had the 50s Trader. The seats in the ,s old Leyland were a bit more comfy looking than Dad's old Mercury.
Pathe 1964 Commercial Motor Show
Re: Pathe 1964 Commercial Motor Show
Nice one Pete I think the Atki Guardsman had a steel cab if memory serves me correctly.
- Real name: Rob
- Has thanked: 195 times
- Been thanked: 281 times
We had a Lynx tipper with an ergomatic cab, 'G' reg I think. I was absolutely certain that the cab didn't tilt and access was via the engine cover in the cab. It was so unreliable it didn't last a year with us and for the amount of times it had fitters crawling all over it I don't ever recall seeing the cab tilted.
hair bear wrote:We had a Lynx tipper with an ergomatic cab, 'G' reg I think. I was absolutely certain that the cab didn't tilt and access was via the engine cover in the cab. It was so unreliable it didn't last a year with us and for the amount of times it had fitters crawling all over it I don't ever recall seeing the cab tilted.
Hi Rob,
I ran some Leyland Octopus tippers and a Bison, all with Ergo cabs and I can assure you they were tilt cabs and access to the engine was easy.
Topic author - Posts: 4072
- Been thanked: 685 times
There were a few levels or standards with the Ergo cab from what I have read. A few were sent out as non tilt. Some cabs were so called deluxe and had more fitments and apparently a double skin for better insulation in parts of the cab. Then later on there was the High Datum cab.
- Real name: craig
- Has thanked: 156 times
- Been thanked: 374 times
Dunno what Ergo's were like to use but they must have looked very modern back then as they still do not look that dated today 56 years later.IMHO
I am not a driver but I did spend some time in an Ergo as a school boy. There were many good things about the cab in the mid 60s when it was introduced but it was not quite a modern as the Ford D series or Dodge tilt cab. The engine cover was very intrusive, possibly due to most of the engines being considerably larger than the Ford and Dodge. (Ford of course tilted the engines slightly and both used V8s for more hp) The AEC Mercury that Dad ran from 69 to 73 was a cracking truck pound for pound.
As the cab aged, like many pressed steel designs from the 60s and 70s, they rusted heavily.
