Help.......I have an old Roughrider, it has a PH1 that works a treat......but the gearbox (3 forward & 1 reverse) doesn't, it will move forward and backwards but the associated noise is quite horrific and it really sounds as if it is about to self destruct. Where can I get parts etc to solve this problem. I also need to fix the brakes & throttle linkages.....again where can I get replacement threaded rods and linkages. All help will be most welcome
Thank You
Liner Roughrider
- Real name: David Heighington
- Been thanked: 51 times
Re: Liner Roughrider
Hi Clive
Try Hydraulic Plant Services who specialise in Liner parts on 01342 327300
- Real name: Les Austin
- Been thanked: 6 times
I also have a small Liner Roughrider, with Petters AVA1 motor. Where can I get a handbook or similar. I can probably find Petters info, but nothing on gearbox or steering box. I just Emailed HPS, but they can not help.
Which section of the forum do I go to in search of Liner comments etc.?
I used to have the full set of Liner equipment parts books etc as the firm I worked for were the South West agents for them.I gave all the books away when we moved
As far as the gearboxes,their main faults were the bearings.We used to strip them down and take the numbers off the bearings and get them locally.
Return to “Contacts for spares and services”
