My newly acquired 2003 Benford PS 3000 needs a paint job but, like a lot of dumpers, the front axle and wheels are covered in concrete from splashes when tipping. Is there a more efficient way of removing the concrete than the 'chippy chippy bang bang' hammer method? For example is there an acid (hydrochloric?) or other chemical that will soften or remove it? Any advice gratefully received.
Rgds CL
Concrete removal
Re: Concrete removal
We used to knock off the worst and then use Brick Cleaner, ( hydrochloric), but it's not a quick fix.
After you use the acid you have to get it painted pretty quickly because any bare meatal will rust in no time.
- Real name: Angus Shapland
- Been thanked: 72 times
Topic author - Posts: 9
- Real name: Paul
Thanks for all the input/interest guys. Shot blasting sounds like the ideal solution but here in darkest France shot blasters are few and far between. A needle gun seems the preferred option of those available. Hydrochloric acid is also an option for the less densely stained areas, combined they may do the trick. After all I just want to tidy it up and cover the rust spots, of which there are many, I don't need showroom condition! Thanks for the advice.
Rgds CL
Rgds CL
We used to use a needle gun to get the worst off then a wire brush on an angle grinder.A good prime and a top coat.This used to be a regular job when I was on the plant We had a fleet of 100 dumpers of all sizes so were kept busy .The worst was removing concrete from inside a large mixer .Inside the drum with a small pnumatic breaker for three days worst job I have been on.
- Real name: Julian
- Been thanked: 13 times
This is similar to the one I have:
http://www.machinemart.co.uk/shop/product/details/cat51-air-needle-scaler?da=1&TC=SRC-needle
I'm not sure that the cheaper ones that are based on a pneumatic chisel are as effective.
You'll need a 3hp compressor for it otherwise you'll be drinking lots of tea while the compressor plays 'catch-up.'
Julian.
Julian.
