after deciding to give our 89 grey cab a fluid & filter change I wish I'd left well alone!
after changing the fuel filters I was left what i thought was air in the system, having tried priming, cracking off the injectors & pressurising the tank, I still have no signs of life
I did read another post that suggested the stop valve in the pump could be a possibility? maybe with me operating the priming leaver something has stuck inside?
any other suggestions?
really peed off right now
3CX fuel issue
Topic author - Posts: 41
- Real name: nicolas
- Has thanked: 35 times
Re: 3CX fuel issue
further investigation, fuel is getting from pump to filter, then onto the injection manifold but nothing after here so not getting to actual injectors?
Re: 3CX fuel issue
fixed
numpty owner before had done some VERY dodgy wiring on the top of the inj manifold which got disrupted on replacing the fuel filter, soldered & heat shrunk, all fired up!
