smoky perkins
gecko.cx
Real name: ian
Has thanked: 126 times
Been thanked: 114 times
Re: smoky perkins
Post #11 by gecko.cx » Tue Feb 22, 2022 4:51 am
aidank wrote:And from what I read moving on the mounting holes 1mm or thereabouts is equivalent to 1 degree in the timing is the rule of thumb I think.
This is easy to work out for yourself.
The circumference of a circle can be calculated by πd, where d is the diameter of the pump flange.
You'll probably remember there are 360 degrees in a circle.
Working backwards, for 1mm per degree, the circumference must be 360mm.
360 / π = 115mm diameter (sounds about right)
If your flange is smaller than 115mm, it will be 'less' than 1mm/degree.
Having calculated that, I'll now suggest you hit it with degreaser and look for graduations stamped on the flange.
For the 4.236, the fuel pump rotates clockwise.
So, rotating the housing clockwise will bing the injection 'closer' to TDC
below are the fault finding suggestions from the 4.236 manual
The very first suggestion for black exhaust is the airfilter as suggested by essexpete!
aidank
Real name: aidan kissane
Has thanked: 1 time
Re: smoky perkins
Post #12 by aidank » Tue Feb 22, 2022 12:03 pm
didnt occur to me to work it out this way, thanks for the calculation.
aidank
Has thanked: 1 time
Re: smoky perkins
Post #13 by aidank » Tue Feb 22, 2022 12:04 pm
essexpete wrote:Not to state the obvious but have you tried running it briefly with the air cleaner disconnected?
Tried that, no difference
aidank
Has thanked: 1 time
Re: smoky perkins
Post #14 by aidank » Tue Feb 22, 2022 12:33 pm
have been trying to figure out as much for my own info as anything else, what should the timing be
Start point: 24degree before top dead centre and continue until 5 degree past or something like that ?
Return to “Tech Talk”
