Norm , yeah , I got her going again yesterday .
Long and short of it is the vertical stack meant for a grey Fergie was almost entirely blocked with carbon
I didn't stretch to new rings and just put the piston I removed back in as was . One of the exhaust ports was bad with carbon and I lapped the valves in although they werent too bad .One of the injectors was carboned up and seemed to be almost completely blocked . I'm thinking I was running on as good as one cylinder since I got it . I cleaned up the outside of the injectors and started dismantling them - I just measured the adjuster clearance with a calliper and re set them to the same depth . I didn't get right into the injectors but by the end I was getting a proper spray pattern out of them and a nice plink .
New gasket set and did the tappets , couldn't help but notice massive play in the rocker arms . The bearings or bushes must be well gone .
Got it back together with the exhaust now just a straight through pipe and she started up eventually . It was a pig to start It's running very clean and I'm now getting a tiny trickle out the spill ( ? ) pipe on top of the injectors which I never got before . I'll need to ask about to see about getting the injectors set , but if it starts easy enough tomorrow i'll maybe just leave it be
What would be the downside if I slackened the injector adjusters half a turn each ?. Would that put too much fuel in ?.
Thanks Norm and others , the machine lives again
Petter PH2
Topic author - Posts: 82
- Real name: Gordon Short
- Has thanked: 4 times
- Been thanked: 13 times
Re: Petter PH2
As I said then a restricted exhaust. That much carbon build up points to over fuelling.
Adjust the excess fuel, ( cold start), screw till you get a near clear exhaust when opening the throttle. I've explained setting up and spill timing the pumps on here a little while ago. look back a month or two. ( posted April 16)
- Has thanked: 302 times
Re: Petter PH2
The good thing about fixing up old grey fergies is that the parts are available and cheap for a complete engine rebuild kit. We did one here and the full in frame kit was AU$500.00 plus had new valves and springs fitted to the head and removed that alloy plug out of the head and fitted a flat welsh plug.
