Jcb 3CX brakes
topkit
Real name: David
Has thanked: 37 times
Been thanked: 157 times
Jcb 3CX brakes
Post #1 by topkit » Sat Mar 18, 2017 8:09 pm
Just been to look at a 1993 L reg 3cx project 8 (i think) checked everything that i could think of on it one bit of play in the steering ram eye which a bush would sort out, but the brakes were not particularly good the transmission was very strong and would still drive the machine on tickover when i was trying to brake the pedal was going a long way down anyone know what this could be. Thanks
pgplantservices
Real name: paul
Been thanked: 2 times
Re: Jcb 3CX brakes
Post #2 by pgplantservices » Thu Mar 23, 2017 10:00 pm
hi david
did the brakes squawk when you applied the brakes?
could just be master cylinders or brake discs worn.
topkit
Real name: David
Re: Jcb 3CX brakes
Post #3 by topkit » Sat Mar 25, 2017 1:28 am
I didn't really hear any noises when i pushed the pedal, i am wondering if there was some air in them although i pumped the pedal and it did not improve at all, iI may still take a chance a buy the machine and first of bleed the old oil out and add new oil to see if that makes a difference.
pgplantservices
Real name: paul
Re: Jcb 3CX brakes
Post #4 by pgplantservices » Sat Mar 25, 2017 7:02 pm
Hi David
if you do buy the machine or go to view it again have a look in the brake reservoir and see if you can smell the oil.
these machines should not have brake fluid in them just hydraulic oil hp15.
if someone has put brake fluid in there by mistake it can destroy the seals.
best of luck
topkit
Real name: David
Re: Jcb 3CX brakes
Post #5 by topkit » Wed Mar 29, 2017 10:15 pm
Thanks, i did check the fluid levels but did not think to smell the fluid, i have to say it did look old it certainly was not a clear fluid, i have found out that it is a back axle out job to do the brake plates about a days work, would proberly try the fresh fluid and as the system is open maybe new master cylinders they are not very expensive then a good bleed may bring the brakes back up.
topkit
Real name: David
Re: Jcb 3CX brakes
Post #6 by topkit » Sun Apr 23, 2017 8:35 pm
All sorted now i got a bit of adjustment on the master cylinder pedal rods then i bledd out the old oil and added new 15 grade and the machine now has brakes so happy days.
Return to “Tech Talk”
