Working on my Benford TT50P "project". It as the Petter PH2 and Newage 40M28 gearbox.
Finally got the engine working after re-working the fuel system.
After about 10mins ticking over, the engine slowed to a stop - I thought it had seized up however the engine would turn OK straight away.
I noticed that when the engine stopped with a shudder, the dumper lurched back/forward a few inches like it had caught a gear.
I opened the gearbox top cover and saw that the box had very little oil in there and what oil there was looked to be emulsified.
The top input shaft area was mostly dry.
I'm guessing that the primary input shaft bearing where it sits into the output shaft had maybe started to seize up against the output shaft near first gear. That area looked dry, black and powdery like it had been hot.
Does this sound like a common problem?
I also notice that the bearing sits high in the box and is probably not sat in oil even if the correct amount is in there? Is this a known issue i.e. you shouldnt leave it ticking over not being driven because the input bearing isn't getting splashed with oil?
Regards,
Julian
Possible Newage 40M28 Gearbox seize causing engine to stop?
Topic author - Posts: 11
- Real name: Julian Corallo
Re: Possible Newage 40M28 Gearbox seize causing engine to stop?
For the 40M series.
Depends on the mod state its either EP90 later boxes or 30 gear oil, depends on the bearings, if there roller then ep90 if there is any yellow metal (bronze) 30 gear oil.
Hi David,
According to the TT50 manual its EP90 but will take another look in the box and confirm.
Regards,
Julian
Regards,
Julian
Hi David,
Stripped the gearbox and one end of the lay shaft has a bronze bush (cup shaped). All other shafts are roller or needle bearing mounted.
Do you think EP80-90 GL4 be OK? I think the GL4 means its OK to use with Bronze bushes? Think the GL5 is the one that causes problems?
Regards,
Julian
Regards,
Julian
PS: the gearbox HAD seized between the input shaft and main shaft. The needle bearing had run dry of oil due to a blocked oil passage. The little dish oil-catcher at the top of the gearbox was blocked.
