wondering the correct way to lube drum bearing on this little old reliable mixer, do I access through cover plate inside the drum ?
Cheers John
PARKER 3T drum bearing lubrication ?
Topic author - Posts: 223
- Real name: John Turney
- Been thanked: 49 times
Re: PARKER 3T drum bearing lubrication ?
taurus MK1 wrote::wave: wondering the correct way to lube drum bearing on this little old reliable mixer, do I access through cover plate inside the drum ?
Cheers John
Hi John,
Should be a grease nipple on the drumshaft.
Hi Fred thanks for that, I will have a closer look tomorrow, thinking greaser might be gone !!! I will let you know.
Cheers John
Cheers John
Hi Fred, I looked but could not find ? I had the cover plate off inside the drum and regreased but only a little, all other grease points on the machine have filled greased caps which I have cleaned out and refilled,they are all working, but I cant see anything for drum support shaft, I could be dumb
Cheers John
Cheers John
