Hydraulic Leak on KH66 Excavator - How to repair?
martyn williams
Real name: MARTYN WILLIAMS
Has thanked: 296 times
Been thanked: 359 times
Re: Hydraulic Leak on KH66 Excavator - How to repair?
Post #11 by martyn williams » Fri Aug 24, 2012 12:39 am
To avoid damaging seals remove cap and rod. Even reseal ram as its now off and you know it will be good for ages.Braze needs to be removed completly if electric welding.I would melt off old braze, check metal pipe is in sound condition.Give the welded area a good clean and rebraze using flux coated rods.With eletric welding, I would say its not a good job to take on if you have little experience.If not welded correctly you may have pin holes in the weld.I would say in this case,I would braze it.If you don't feel confident in yourself to do it yourself.There may be a firm local to you that will do it for you.Good luck :thumbup:
ontick2
Real name: lee
Been thanked: 3 times
Post #12 by ontick2 » Fri Sep 21, 2012 7:20 am
Just thought but remember to keep the ram closed as not to damage seals.
Thanks Lee.
Return to “Tech Talk”
