Jc3cx 4 idle adjustment
Topic author - Posts: 9
- Real name: Ryan
As title as one know how to adjust idle on a jcb. 1982 perkings engine is it the cable or can you adjust it on the pump. My cable seems to be on full adjustment. Thanks
- Been thanked: 191 times
Re: Jc3cx 4 idle adjustment
On the injector pump,at the throttle lever where your cable is connected to,you'll see 2 adjusting bolts with lock nuts.The one towards the front is the idle stop. Sometimes a tension spring is required to pull the lever back against the stop to get tick over.
