JCB 215 ignition problem
I has been working with the 215, stopped to talk to a person, shutting it off then went back to start it up and NOTHING... I made sure it was in neutral and tried again, still nothing. I checked underneath and didn't see anything out of place. tried again and again no luck. I checked the fuses, they were all good. It shows the normal lights in the dash and I hear relays clicking in the fuse box area, but I'm not sure which should be clicking, so I don't know what I should check next. Any ideas and suggestions are greatly appreciated!
- Has thanked: 1881 times
- Been thanked: 1695 times
Re: JCB 215 ignition problem
This may sound like a daft suggestion but have you made sure that the battery connection has not come loose and that the battery has not suddenly had a cell fail?
If the battery is okay the next thing I would look at would be the switch itself.
Users browsing this forum: Bing [Bot], Rich Knowles and 19 guests
