Jcb3c11
Topic author - Posts: 10
- Real name: Russ
Jcb3c11
Hi, I've got a problem with oil coming out of the king post just above the slew, does anyone have any suggestions?.
- Real name: phil wheelton
Re: Jcb3c11
Sounds like slew seals leaking take the plate off behind the king post the one with the small pipe bolted in it if it's full with oil the slew seals are leaking the oil is ment to be up to the mark round the long bolt in the center.
- Real name: Russ
- Real name: adrian fleming
Re: Jcb3c11
thanks but done a bit more checks on her n found the pipe to the steering rams was loose just under the hydraulic cylinder on left side ,so i tightened it u then everything went west, juddering hydraulics and the hydraulic cylinder one inside compartment has been exteneded with a 2 inch hose does this help anyone have a reason for this ,or a workshop manual or hydraulik diagram please adrianawol64 skype if any 1 can help
