Hello dear friends,
there is transmission oil leaking from the dipstick tube of the gearbox. There is no water contamination, and hydraulic oil is not leaking into the gearbox. The leak is not caused by overfilling - when the transmission leaks oil there is less and less as the time passes.
First time I was thinking it could be caused by the clutch, but it is still leaking even when the JCB is not moving, and the oil is not boiling. It looks like some kind of pressure is building up in there and because of it is the oil leaking from the dipstick tube. Could it be some kind of a foul vent?
Its a JCB 3CX SuperSitemaster y.2002
I will be happy for any suggestions, I really do not know what could be causing it. Thank you.
(sorry for my bad English)
JCB 3CX transmission oil leak from dipstick tube
- Real name: Wyn Jones
- Been thanked: 8 times
Re: JCB 3CX transmission oil leak from dipstick tube
sounds like the breather is blocked
Nothing runs like a Deere, - being chased by a big Cat..........
Topic author - Posts: 2
- Real name: Thomas
Thank you for your reply. Can you tell me where is it located? From the bottom I do not see nothing. The gearbox is not dismounted from the machine. Can I reach it from somewhere and clean it? Thanks in advance.
Wings400 have you been able to solve the problem because i am also having similar issue with my JCB 3CX. Will be glad if you could assist me
silly question, but when i got a filter kit i was given 2 engine oil filters... is one for the gearbox?? they are the same size....
- Been thanked: 686 times
rich. wrote:silly question, but when i got a filter kit i was given 2 engine oil filters... is one for the gearbox?? they are the same size....
I seem to remember the Leyland engine and BorgWarner velvet shuttle filter were the same.
Gearbox does have a filter yes, top side of the box, can only see it from underneath, always get a nice trickle down your arm when you change it.
