The previous owner had taken the cylinder head off (9 months ago), thought the problem is "un axe de piston qui a du jeu", my youngest daughter said "the piston wants to play" but the jury concluded (roughly translates to) "the piston pin has a lot of play". I think that a/several Gudgeon pin is loose/circlip problem. Other things as well I expect.
Well I intend to try and replace the damaged/worn parts in the existing engine (with my very limited knowledge and equipment), expect me back on the forum on a regular basis for help and information (updates), when my day job allows.
What do you think this is?
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Re: What do you think this is?
Sounds good to me.
Topic author - Posts: 26
- Real name: Jon Dobson
Here are the first photos as promised...
can any body tell me if the rocker assembly and push rods are they the same for the Leyland 38td and 49/ NT engines
- Real name: Phil F
- Has thanked: 18 times
- Been thanked: 108 times
yellow wrote:The previous owner had taken the cylinder head off (9 months ago), thought the problem is "un axe de piston qui a du jeu", my youngest daughter said "the piston wants to play" but the jury concluded (roughly translates to) "the piston pin has a lot of play". I think that a/several Gudgeon pin is loose/circlip problem. Other things as well I expect.
Jeux in this is definitely play. Where in france are you? Assuming not canada or belgium etc that is.
Sent from my MB526 using Tapatalk 2
- Been thanked: 686 times
yellow wrote:OOP's ment Leyland38TD and 4/98 NT, regardless of age.
If you don't get an answer here try the Leyland/Nuffield tractor forum, or the classic section of the British Farming Forum.
