What do you think this is?
- Has thanked: 7 times
- Been thanked: 43 times
Re: What do you think this is?
I was referring more to the lower part of the front grill. There seems to be a big bit of sheet metal that isn't at the usual diagonal angle that most of these machines would of had. The loader arms would be appropriate to a 3mk2 as theyre smaller than the mk3. Is the engine in the machine 3 cylinder?
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
There are lorrys that have cranes that will lift these. I've had two diggers lifted this way. Its a wee bit expensive. Is the engine seized? If it isn't seized. It more than likely will run.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
Topic author - Posts: 26
- Real name: Jon Dobson
Engine not seized, so may be it can be winched. The question that springs to mind is No hydraulics, electric cut (no starter motor), how do we deal with front bucket and rear actor/bucket on the ground on a winch in.
Vendor says 3 cylinder Leyland, but yet to confirm with my own eyes.
- Real name: Brian
- Been thanked: 30 times
you'll need a Hiab mate unless you can rig up a starter motor and get it running. Those old engines usually dont take much to get going
Is their another digger or tractor with a loader that can lift the back actor clean off the ground and also the loader. When you have the back actor lifted chain it to the king post carrie, pop a bit of angle iron between the ram cap and the loader to keep it up off the ground and then winch it up.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
- Been thanked: 191 times
I see there is a 3mk3 for sale on gumtree at the moment about Armagh.It doesn't look bad in the picture although the seller says its going for little over scrap value.
Its a good value digger at that price - with time there may even be a profit in it!
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
I know I should but I wont!
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
finally got a picture of the back end - does this look correct for a 3 MKII?
