Hi folks, looking for some help!
A friend of mine has a 3CX which is blowing a fuse when he puts it into 4wd. It runs fine in the 2wd and 2/4wd setting; but when he select 4wd it blows the fuse. He had me clean and reconnect a couple of connections under the body of the digger to see if it was a loose connection, but still no fix. At first it blew the fuse after a few minutes running back and forward, then it blew the fuse as we sat and thought about things - the drive was in neutral but 4wd was selected. When we tried it a third time it ran fine for about 5 minutes before we had to stop.
Any ideas on what is causing the problem? He's reluctant to take on any work until we fix this problem
JCB 3CX 4wd Fuse blowing
