jcb 3c mk2 slewing slack
Topic author - Posts: 9
- Real name: james colwell
my jcb 3c mk2 has a lot of slack in the backhoe and i was wondering whether i should take the 4 big bolts out and slide the backhacker down because the spline gets worn and creates slack. if i did strip it down what should is do to it. also were could i get slew seals for it
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
Re: jcb 3c mk2 slewing slack
jamescolwell747 wrote:my jcb 3c mk2 has a lot of slack in the backhoe and i was wondering whether i should take the 4 big bolts out and slide the backhacker down because the spline gets worn and creates slack. if i did strip it down what should is do to it. also were could i get slew seals for it
Hi James, have you checked the condition/level of the oil in the slew rack gear box, its often forgotten on services and tend to get water contamination, a good flush out and refill works wonders Mark
- Real name: Adam Carter
The seal kit you need is 991/00011. I think you need two kits.
You could try FPE Ltd (Fluid Power Equipment) on 01325 282732.
- Real name: John Cafferkey
Hello! Does anyone know where I could find an original Yellow Badge with Black JCB initials for the White Steering Wheel of a JCB 3C MK2? Condition is not important as long as its a yellow badge with black initials.
Many thanks
John
Many thanks
John
- Has thanked: 7 times
- Been thanked: 43 times
Now theres a question. I think you're only going to get this from JCB
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
johnhurstcafferkey wrote:Hello! Does anyone know where I could find an original Yellow Badge with Black JCB initials for the White Steering Wheel of a JCB 3C MK2? Condition is not important as long as its a yellow badge with black initials.
Many thanks
John
While you're looking, if you come across one with a red badge (3D) I'll have it please! Will post you the JCB part number when I get home. Mark
- Real name: phil wheelton
Is your slack in the rack or is there air in the slew circuit hydraulics there is a bleed screw the valve block to bleed the air out of the circuit there is a cap head screw in valve block above the lower ARV if you slack it off and hold the slew one way it bleeds the air out if the slack is in the rack this won't help but worth trying first before any big strip down.
the problem was the spline that goes from the slew rack into the backactor was razor sharp so put some chemical met on the spline and its like a new machine. thanks for all the posts on what to do
I changed my hydraulic filter because of a hesitant backhoe which wouldn't dip or return very well and is very slow on the slew. This hasn't improved it, and am concerned that it might be a case of air in the system.
Would my old 2B II have faciliity to bleed out the hydraulic system or could it be something else?
Nick
Jcb 2BII and handstart single cylinder dumper
