Post #12 by holzrainer » Thu Mar 22, 2012 8:31 pm
Hello,
after paused all over the winter I finally found some time for starting to fix my brakes.
I have been waiting for warm weather because I have to work outside.
First I removed the seat, the screws were really tight und the metric tools don't really fit the imperial nuts.
Then I searched the bolts for the floormate by removing lots of mud and dirt, in the lower backside of the cabin I found a lot of things, screwdrivers, some wrenches, some cloves and lots of dirt, think I can start a nursery.
I found a removeable plate in the back and could remove the right plate over the axle.
The left plate is still held by the spring of the brake pedal.
Up to now : the spring of the throttle pedal is broken, one spring of the brake pedal is missing.
The adventure will be continued.
Regards
Rainer
