Just bought this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290591257501&ssPageName=STRK:MEWNX:IT every thing works except most of the lights, the gauges seem to work since pressure washing inside and out. even the brakes work a bit. the bad bits are cab quite badly rusted and its had a big bash on the front corner. I intend to do it up a bit, not a full restoration just stop it from deteriorating any further.
If anyone can help me source a manual that would be a good starting place.
New oner of JCB 3D
Topic author - Posts: 26
- Real name: Tim Arnold
- Been thanked: 2 times
New oner of JCB 3D
Tim Arnold
http://www.parklandsholidays.co.uk
JCB 3D3, Benford 1ton Dumper, Benford Pedestrian Roller.
- Has thanked: 7 times
- Been thanked: 43 times
Re: New oner of JCB 3D
Thats a real good machine you've got there and at a great price too.
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
That is quite a straight old machine you have got there, i did look at it myself, hopefully you can get that kingpost sliding across the back of the machine again, i doubt if it is anything serious, it is proberly one of the clamps or it may even just be seized, if you keep your eye out on Ebay you will fine the engine manuals and workshop manuals do turn up quite often (i got all of mine on there) there are also the disc versions on there at the moment. Good luck
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
No need to look on ebay, if we dont have the manuals here ...http://www.classicmachinery.net/forum/downloads.php?cat=5 and they is free
if not then i am sure Mark will have them
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
Hi Tim, nice machine, welcome to the 3D owners club As Martyn said manual is here in the downloads section. Anything else you need just ask as i have lots of info on these machines including full parts manuals and numbers. Please don't buy any manuals from e-bay without asking me first, because if I have it then its free to all forum members Cheers for now Mark
Thanks for the link for the manual, it appears that i need a lot of hydraulic fluid, anyone point me in direction of a good value supplier.
I dont intend doing a full restoration just look after it and give some tlc,
It seems like a lot of others on here it makes me sad to see old machines rotting away or cut up for scrap.
Tim Arnold
Tim I just got 200 litres of hydraulic oil that had only done 22 hours in a machine. Friend off mine works for a plant firm, they changed the oil on this machine then it threw the hydro pump, so they drained the whole lot off when they fitted the new pump (warranty job) lucky me eh! All that aside, we have a couple of firms here that sell off the old oil, I know its not the way to go but at 50p a litre its a cheap way of keeping an old leaky machine running. there might be some place around your way that would do the same for you if you dont mind using old oil. One place here even filters the oil before they resell. Mark.
I'm exactly the same as Mark. I never buy hydraulic fluid. I only use secondhand. As long as its filtered it'll work fine. Just out of curiosity how much is hydraulic fluid now? About a couple of years ago I think I saw some for sale at around £30 for 20 litres.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
