Hi All,
I'm new to the forum and this is my first post.
I have a 3C11 which I've owned since 2003, she only has occasional use to do some self build and work around the farm but been one of the best investments of my life.
A problem I've always had is that the back actor has a huge amount of overshoot/play which I've learned to cope with but would rather fix. Somebody suggested its easy to do as its just a change in seals. Is this the case ?
Chris
JCB 3C11 Back actor play
Topic author - Posts: 4
- Real name: Chris Moore
- Real name: Mark Rive
- Has thanked: 33 times
- Been thanked: 26 times
Re: JCB 3C11 Back actor play
Hi Chris, welcome to the forum On an old machine most likely is a worn slew rack. But also the following may apply. Air trapped in the ARV cavity. (aux relief valve) Dirt on the ARV seat. Dirt in the anti cav valve seat. U/S ARV. U/S Anti cav valve, and the ram seals. Also worth draining of the slew gearbox, its probably got water in it and refilling with HD90 or similar it takes a gallon. You can download the workshop manual for your machine here. click on downloads search for JCB and follow the links. In fact I'll copy and paste it in a min. Cheers, Mark
here's the link. JCB 2D, 2DS, 3, 3C, 3CS, 3D and 700 Backhoe Service Workshop Manual
if you need further info just ask, but i'm sure someone here will know more about this than me. Cheers Mark
Mark,
Thanks, that's really useful information, lets hope its one of the simpler problems.
Cheers
Chris
Cheers
Chris
- Has thanked: 7 times
- Been thanked: 43 times
Yes Chris definately drain and change the oil in the slewing actuator first and see how you get on. I've just done digger number three and again its 95% water. Was talking to a bloke who has a 3Dmk3 and his is very slow to slew in one direction but ok in the other. I would assume he has water in his actuator as well. In fact I would urge anyone with a 3C/3D machine to get this simple but easily forgotten oil change done.
William
JCB Hydra Digger Loadall 65
JCB 3DIII Powertrain
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
chris.moore12 wrote:Just drained it, at least 95% water!!!, now to refill.....
knew it thats gonna make a world of difference Chris.
So 4 litres of EP90 later and its tight as you like to the right and much improved and still improving to the left. Gosh that was easy. Thanks guys !!
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
Just looking at this post can any of you please tell me where the drain plug is for doing this job, i have been looking but can't find it unless is is hidden under a load of mud lol. I just want to do a drain and refill as part of my service routine before i start using my 3c mkII again. thanks in advance
It will more than likely be filled in with mud. Its dead centre on the underside. A 1 inch drive ratchet fits directly into it.
William
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
JCB 3DIII (Manual)
JCB 3DII
JCB 3CIII
JCB 805B
