JCB 3C11 Back actor play
mart31_uk
Real name: martin
Re: JCB 3C11 Back actor play
Post #31 by mart31_uk » Tue Jan 02, 2018 12:25 pm
great photos, i have the same problem with play in the slew. re. the drain plug photos, i think i can see two plugs underneath on the photo and am i rigbt to assume its the one on the right that i need to drain it out?
if so, does anyone know what the one on the left is for?
i am more than a little worried about dumping all the hydraulic fluid (120 litres or so of it) in to a 5 litre tin :-)
cheers
martin
Tillywolves
Real name: Richard
Has thanked: 11 times
Been thanked: 19 times
Post #32 by Tillywolves » Fri Jan 05, 2018 8:35 pm
Yes Martin, the one on the right of the photo. It will only drain the slew gearbox oil, about 4.5 lts of water in my case.
mart31_uk
Real name: martin
Post #33 by mart31_uk » Mon Jan 08, 2018 12:35 pm
thanks for confirming. the cover on mine is also buckled, so am assuming frost damage caused that.
incidentally, i used wynns engine flush when changing the engine oil and i have never seen such dirt come out with oil before (and i have changed a lot of oil over the years).
topkit
Real name: David
Has thanked: 37 times
Been thanked: 155 times
Post #34 by topkit » Mon Jan 08, 2018 9:13 pm
I am in the processes of doing my project 7 3CX i hav taken the drain plug out and ot the usual sludge out just wondering what to use to flush it the rest out, i have new slew pot seal kits so i suppose it does not matter what i use as i will be re sealing it all.
mikefoxo
Real name: Michael Fox
Has thanked: 3 times
Post #35 by mikefoxo » Tue Jan 09, 2018 6:56 pm
My father has a 3MkII with a sloppy slew. It's a small bit different to the other pics so I said I'd just check with the experts :D In the first pic it has a large plug with a breather coming put of it - I'm guessing this is where you fill it up. In the second there are two plugs. The big one at the top is nearest the back of the machine - is this the one I open? Thanks in advance
Tillywolves
Real name: Richard
Post #36 by Tillywolves » Mon Jan 29, 2018 9:20 pm
I cant say for sure as I've never seen a mk2. The plug with the vent will be the filler. The other two plugs, are they at the bottom of the assembly.
Has thanked: 976 times
Been thanked: 890 times
Post #37 by FOWLER MAN » Tue Jan 30, 2018 11:55 am
If I remember rightly both bottom plugs to drain and the large plug n top with the drain, (breather), is the filler. There should be a dipstick attatched to the underside of that plug.
As you probably know the oil is EP90.
