McSpud wrote:Hugh, in that case you describe, did the head gasked need replacing afterwards?
S
No it would not need replacing unless the machine overheated again and that was found to be the problem, engines can overheat for all kinds of reason but I suggested that the symptoms of your machines problems sounded to me like the head gasket had gone because most of the other problems that can cause a motor to boil had been ruled out.
I think that the best course of action for you is to carry on using the machine but keep an eye on the temperature guage and if she boils again while she's under load then I would suspect that the head gasket is the problem.
You will soon find out because if it is the head gasket thats started to leak then the motor will boil again under load.
