JOHN DEERE BACKHOE
Topic author - Posts: 112
- Real name: 450lc
- Real name: IBH
- Has thanked: 12 times
- Been thanked: 87 times
Re: JOHN DEERE BACKHOE
John Deere did bring their backhoe loaders and other construction equipment to Europe in the early 1970's but withdrew against strong local competition and as a result of the financial crisis.
None have been sold since then, but apparently Bell was considering bringing the South African built side shift model(s) to the UK, but have not yet done so.
I have run JDs since the 70s started with a 2010 4in1 tracked loader fitted with a backhoe,that was traded in for a new 310 wheeled loader backhoe,then we traded that for a new JD410. They never seemed to catch on but I cant complain the 410 is still working after completing over7000 hrs and the only major fault was porous liners.I always liked the view from the operators position of the front bucket and backhoe 2nd to none as far as Im concerned.
- Real name: David Heighington
- Been thanked: 51 times
- Real name: martyn henley
- Has thanked: 38 times
- Been thanked: 50 times
Any images anyone of John Deere products?
Well Dave, i found these ....
This believe this is their current model the JD 410H, must say it looks familiar
I remember AMT did a great plastic kit of this one, many years ago
and this one is the side shift version
- Real name: Dave
- Has thanked: 57 times
- Been thanked: 5 times
JD Scraper of JC Balls & Sons
And a restored JD tractor which are alot more common
JD Engine unit at SED
Got a couple of JD teleporter photos some were, but not seen much else from JD
Dave
Dave
- Real name: Taylor Lambert
I have a friend that has an older John Deere 410 tlb. He uses it around his sawmill for moving logs and off bearing sawdust as well as use around his farm. Dad had one when he worked for Wright Brothers Construction when I was a pup. Hw kept it to lay the smaller pie when he wasnt on his 245 Cat. I was helping my friend fix a leak on it I noticed its said made in Manhiem Germany. The motor and the frams both said it, I talked to a fellow from Germany and he said that Deere wasnt popular there.
My friends machine is a sideshift with a scissor setup on the out riggers with telescoping arms. Hes only used the sideshift 3 times in 22 years but its been handy when he needed it. I like the looks of it alot heavier than my 3550 but also a bit cumbersome. His looks alot like the last pic.
