JCB 3CX Back hoe not slewing left/right
- Real name: Gethin Davies
Re: JCB 3CX Back hoe not slewing left/right
Thanks for the picture showing the procedure. I will try that tomorrow. the only thing was I found the padlock leaver not to be very responsive?? I'll let you know tomorrow if I succeed.
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
You wont feel much with the leaver all it is doing is letting the pressure off from the four hydraulic clamps that hold the kingpost in place, The are the four round pots two at the top and two at the bottomof the kingpost corners, once the pressure is released then the kingpost will move.
topkit wrote:You wont feel much with the leaver all it is doing is letting the pressure off from the four hydraulic clamps that hold the kingpost in place, The are the four round pots two at the top and two at the bottomof the kingpost corners, once the pressure is released then the kingpost will move.
Did as you suggested today and it worked perfect thanks for your help
Users browsing this forum: Google [Bot] and 57 guests
