Hi all.
The stabilizer leg levers are operating together how do I get them to work independently.
Mitch
Stabilizer leg levers in cab
Topic author - Posts: 9
- Real name: Mitch parsons
Re: Stabilizer leg levers in cab
Thank you for that. I'm starting to get it ready for the winter so I'll have ago with that.
Regards
Regards
- Real name: ian
- Has thanked: 126 times
- Been thanked: 114 times
Not familiar with the model, but looking at the P7, the two leavers seem to share a common pivot pin, so a penetrant it a likely fix.
It's possible the anchor plate the levers attach to is loose, so both are moving together.
Once you get eyes-on, I think the problem will be clear.
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
I had a very similar problem on a fermec 860, I had to take the levers apart as the had corroded onto the shaft after i soaked everything in plusgas i eventually got them and the shaft of the. Digger and then got everything apart and made a new shaft the refitted everything with plenty of grease!
