Repacking my 3cx (1400B) 1987 yr lift cylinder and the seal for the gland cap were destroyed. I can not figure out the gland cap seal order for the inner seal area. My set does not have a new wear ring (pic 3) but has two seals for the inner gland. Any idea on the order and orientation of the seals?
Thanks for the help....
Seal order - repacking loader lift cylinder 1400B
Topic author - Posts: 19
- Real name: Ed Moor
Re: Seal order - repacking loader lift cylinder 1400B
the seal with the o rings is the outer most seal (with o-ring toward piston). its the order of the other two rings....call it wear ring in pic three. is that the final seal ring towards piston with the black seal in the middle?
- Real name: ian
- Has thanked: 126 times
- Been thanked: 114 times
I'll bow out in that case. Mine is a P8 (10y newer) and the seal arrangements are quite different - certainly no wear ring in the gland.
Back together and leak free.
