essexpete wrote:Is that an electric shuttle or manual lever shuttle?
It has the electric shuttle shifter on the steering column.
agrimax wrote:That'll be known to us in the UK as a project 7 grey cab with Synchro shuttle and electric f/r.
If the box is in neutral,there would be no wheel movement at all when the shuttle lever is engaged. The shuttle part of the transmission has a torque converter rather than being hydrostatic. Have you dipped the oil level in the transmission? (Perhaps you already know or maybe not but the tranny oil is totally seperate from the hydraulic oil in these,and uses an automatic transmission fluid(ATF).
Users browsing this forum: Bing [Bot] and 50 guests
