1982 Machine that will probably have the Borg Warner shuttle and a Perkins engine. The cab would have originally been white.
Worth checking the state of the transmission fluid, you dip whilst the engine is running. The oil originally was recommended to be a 10w transmission fluid but others have used an ATF without a problem. (ATF usually a pink/red colour. The gear box is a synchro 4 speed with a level plug. That needs an oil compatible with synchros. The rear axle needs a gear oil compatible with oil immersed disc brakes.
JCB 3CX identification
- Real name: Jeremy Rose
- Has thanked: 7 times
Re: JCB 3CX identification
Hi guys, what is the best way to identify the ram seals for ordering new ones?
- Real name: ian
- Has thanked: 126 times
- Been thanked: 114 times
First port of call is probably the JCB parts list online
https://parts.jcb.com/parts
Enter your serial number and it will offer you what was available at the time (not specifically what is on your machine).
[edit: I've just tried your serial and I can't get anything]
- Real name: norman orrick
- Has thanked: 144 times
- Been thanked: 132 times
supermondo.
I've recently done the boom seals on my 3cx and got the seal kit from Vicary Plant Spares (about £20) they seem to be the go to guys for that sort of thing.
Norm.
Norm.
Pete.
Just used the ten fingers and thumbs type they went on without to much faff, unlike the King post pin which I posted on here. The guide part of the seals are split so no bother with them and the O rings being new are very flexible.
Norm.
Norm.
- Been thanked: 685 times
I got in mucking fuddle with a gland seal on the 814. Could not get one in. Bought the plier things, then snapped the seal. I think the seal had been hanging around a while.
- Real name: ian
Heating the seal in hot/boiling water does help (a bit) to soften the seal.
If your seal was old and hard, it may have been a blessing is disguise that it failed before reassembly.
