Good Morning All.
I am after advice on renting engine on my 3cx white cab. In nut shell ... engine went for rebuild.. I managed to remove it with torque converter after a bit of jiggling ...
Now is there easy way of refitting it back ? The engine has the converter still attached. I didn't lower the transmission or the gearbox. Is it a matter of just sliding it back in and bit of side to side and get it fitted ? Or do I need to lower the transmission/gearbox and fit that to the engine once lowered in to place ?
Is it worth changing plates on B&W before I do that ?
Thank you.
Jcb 3cx white cab engine refitting....
Topic author - Posts: 2
- Real name: Sly
- Been thanked: 684 times
Re: Jcb 3cx white cab engine refitting....
A long time since I helped a very good fitter separate the engine and Borg Warner transmission on both a JCB and Sanderson. I remember the critical thing is getting everything square and easing in very carefully to avoid damage to the main seal as the shaft goes in. We never had the engine and transmission both lowered/removed at the same time with either machine.
- Real name: Ian Perrott
- Has thanked: 90 times
- Been thanked: 88 times
Hi
I did one on a 1987 3cx with a Perins 4.236 engine a couple of years ago and it had the torque still attached, we had to remove the radiator and also undo the oil intercooler in front of the rad, it's a bit of a fiddle and it needs to go in at the right angle so getting the slings at the right angle is the key, we had a tractor loader with creeping hydraulics and cracked the front windscreen but as you say with a bit of patience and side to side movement it went in, good luck
Ian
Ian
- Real name: Sly
Cheers Guys! Yeah slow and careful will be the way then !
Users browsing this forum: Bing [Bot] and 29 guests
