HI guys,
New member here, I really appreciate all the knowledge on here, already leaned so much I have a new to me 1987 3cx that I am wanting to do some work with... I have little to no experience with backhoes so the learning curve is steep here
One issue I am having is that the hydroclamps don't seem to be functioning quite right... Instigating under the plastic cover it seemed that the lever and linkage that rotates the hydroclamps valve was ok... But undoing the linkage I can what looks like a little oil leakage and the splined ring that it clamps round can be turned indefinitely by hand. Is this normal?? If so how do I know what's on and whats off?
The diagram in the workshop manual looks somewhat different to the layout I see on this machine. But It says in the manual to screw it fully in then undo 180 degrees, to get it properly positioned...
I am tempted to investigate further and start undoing the assembly, but would love some guidance. If I undo it with the engine off and the boom in a resting neutral position (found by moving the leavers every way with the engine off), will I be faced with a torrent of hydraulic oil? what precautions should I take? Any other thoughts or guidance would be really appreciated. Thanks, Steve.
should I be worried about replacing these perished and missing grommet protector bits - if so anyone know where I can source some from, and can I get ones that slide on without undoing hoses? Thanx.
New to me 1987 JCB 3CX hydroclamp question
Topic author - Posts: 3
Re: New to me 1987 JCB 3CX hydroclamp question
Bump. Really could do with some help on this one guys, any thoughts?
- Real name: Gordon Short
- Has thanked: 4 times
- Been thanked: 13 times
Haven't a clue about the hydroclamps , that does look a weird set up . Does it rotate indefinitely when the engine is running ?.
On the hoses I'd just cut a bit of rubber and wrap it round and get at least one cable tie on the protruding bit . Always a bit wary about doing too much protecting and trapping moisture and crud tight against the hose . No doubt you could buy those grommets somewhere .
Land Rover wrote:Haven't a clue about the hydroclamps , that does look a weird set up . Does it rotate indefinitely when the engine is running ?.
Thanks, not actually tried rotating the collar thing with the engine running, good idea, I will try that tomorrow and report back.
