Hi All,
This is my first post in a while although I have found loads of useful information in the past. I have a JCB 3D, according to the operators handbook which I got from this site, in the "Kingpost and stabiliser" section, section 6 page D-2 it says to "check the actuator bleed off pipe daily, oil dripping from this pipe would indicate a seal failure" I have hydraulic fluid pouring from this pipe which is very frothy like it's full of air. Any suggestions as to the cause and what seal may have failed. I can't seem to find any other reference to it in the handbook or workshop manual. Cheers
JCB 3D help
- Real name: phil wheelton
Re: JCB 3D help
If you have oil leaking out of the breather in the kingpost it will be the slew seals leaking into the rack and pinion ,
