Hi guys,
What grade gear oil should i refill my kingpost with after i release undo the bottom bung to clear it out?
Im expecting some water and gunk to come out first
3c3 kingpost oil
Re: 3c3 kingpost oil
ehannon wrote:Hi guys,
That will be HD90 gear oil. I have used EP90/140 multi-grade too with no problem.
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
As Fred says HD90 gear oil, I have just done my 3cx slew box, let it drain for a few hours, As if it has not been done for a while there will be a mixture of oil, water and sludge, I poured oil in with the drain plug out so I flushed more sludge though, you can get your finger inside the drain hole to pull the sludge out. They say do not refill to the brim leave about a thumbnails distance from the top of. The fill point.
Users browsing this forum: No registered users and 61 guests
