1994 JCB 214
After an hour clearing snow the machine stopped going into forward or reverse. The action of the shift lever itself functions well - the detentes are solid - no sloppiness. The symptoms include - parking brake buzzer is ON when the parking brake is on and the shift lever is in NEUTRAL. The machine continued to run fine immediately after the forward/reverse command stopped working (and I had to drag myself back up the hill with the hoe to get it out of the way of traffic.) Once the machine was stopped it would not start again. Operators manual says the machine will not start in gear and, as mentioned above, the parking brake buzzer sounds when the shift lever is in neutral with the parking brake on. Is this a simple wiring issue? Corrosion, broken wire? (Where would I look for this?) Haven't checked the fuses yet - it's dark out and it's cold and it's a PITA. Does anyone have any sage words?
Thanks in advance,
Alex
1994 JCB 214 forward/reverse INOP
- Has thanked: 1867 times
- Been thanked: 1688 times
Re: 1994 JCB 214 forward/reverse INOP
Daft question Alex but had your machines brakes frozen on? Give it a try today?
Topic author - Posts: 9
- Real name: alex
- Has thanked: 3 times
Jeremy, I checked the brakes. They are releasing ok. I am (we all are in my neck of the woods) suffering from hideous cold weather so I haven't made the time to do any work on the machine... and haven't had any suggestions either.
Alex
Alex
- Has thanked: 849 times
- Been thanked: 680 times
I am guessing this is similar to the 3CX of a similar date? Is it a non power shift with manual gear box? If a manual then place it in neutral on the main gear lever. Then short out the starter solenoid. If this works you might have a problem in the wiring with the shuttle neutral safety switch.
- Real name: alex
essexpete wrote:I am guessing this is similar to the 3CX of a similar date? Is it a non power shift with manual gear box? If a manual then place it in neutral on the main gear lever. Then short out the starter solenoid. If this works you might have a problem in the wiring with the shuttle neutral safety switch.
Hi Pete,
Not sure of the similarity with the 3CX. My machine is a synchro shuttle transmission. Thanks for the tip. When the temperature warms up I'll be out there digging around and I'll try this out. May have to resurrect this thread.
Cheers,
Alex
