jcb 3c mk 1
Topic author - Posts: 3
- Real name: shane howland
jcb 3c mk 1
i have a problem with the power steering it turns one way but not the other I dropped the bottom of the ram of and it goes in and out. I need a drawing of some sort to explain how it works.. can anybody hellp
Re: jcb 3c mk 1
Hi Shane and welcome sorry I can't give you much advice but I would start by getting the hydraulic fluid pressure to each side of the steering ram measured first, daft question here but is the ram 100% straight? Just a couple of ideas to run past you.
Re: jcb 3c mk 1
yes the ram is straight I think it may b the steering box. I disconnected the ram at one end it goes in and out with a little help. I have bean tool there's a butterfly in the end of the ram to move the ram in and out.so I might have to strip it down to find the problem .
Re: jcb 3c mk 1
shamas wrote:what is a spool and a drag link ?
A spool is a control valve that lets hydraulic fluid flow to the ram in each direction as required; a drag link is usually the bit that connects the steering box or ram to the axle on the one side of a machine.
