perkins A4-212 timing
Whitlock 505
Real name: Ian Perrott
Has thanked: 90 times
Been thanked: 88 times
Re: perkins A4-212 timing
Post #11 by Whitlock 505 » Sat Mar 10, 2018 10:16 pm
Whitlock 505 wrote:Is it me or do the splines on the crankshaft internal gear look flattish? The one with the socket on? Could it be they are worn and not meshing properly or slipping?
Ian
Just seen the setup of a 212 crankshaft and it is splines with a keyway shaft behind it :dizzy: apologies
Has thanked: 1295 times
Been thanked: 1111 times
Post #12 by FOWLER MAN » Sat Mar 10, 2018 11:44 pm
Hi Ian,
That's an easy mistake to make but if you look closely at that pic. you can see the end of the keyway in the crank shaft gear at about five to the hour.
Users browsing this forum: No registered users and 47 guests
