Dipper Ram seal - 89 3cx
Discuss loaders/backhoes here
kerniki
Real name: nicolas
Has thanked: 35 times
Been thanked: 1 time
Post #1 by kerniki » Mon Nov 27, 2017 10:05 pm
Hi guys,
got a seal gone on the dipper ram, have read up a bit on replacing and found the 'beware the gudgeon pin' pointer.
question is; were there many variations over the years for this ram? trying to locate the part number for my particular machine and having difficulties so was kinda hoping that the seal is an obvious part number for the 89 model?
any ideas?
Has thanked: 853 times
Been thanked: 684 times
Re: Dipper Ram seal - 89 3cx
Post #2 by essexpete » Tue Nov 28, 2017 1:15 am
Well you might do worse than contact your nearest JCB agent sometimes they can reference an old machine.
kerniki
Real name: nicolas
Post #3 by kerniki » Tue Nov 28, 2017 9:01 am
sorry, should have said, i live in france and my language skills aren't quite good enough yet to discuss something so particular so need to do my recon work online and give part numbers, guess i could ring a job dealer in uk but don't feel right about using them and not giving them the £
Land Rover
Real name: Gordon Short
Has thanked: 4 times
Been thanked: 13 times
Post #4 by Land Rover » Tue Nov 28, 2017 12:23 pm
You should find you can search this website and find the part number required .https://parts.jcb.com/
Or call / email Vicary Plant and give them your machine serial number http://www.vicaryplant.co.uk/
There must be dozens of JCB 3CX's in France , there seems to be an enquiry from someone based in France regularly .
kerniki
Real name: nicolas
Post #5 by kerniki » Wed Nov 29, 2017 9:32 am
all sorted and in my hand, thx gents.
now to find that dwell that people speak of, can't see it at first look and nothing showing on my workshop manual, is this spigot / dowel on the smaller rams maybe?
Mabel
Real name: Tony
Been thanked: 2 times
Flag: France
Post #6 by Mabel » Wed Jan 31, 2018 7:47 pm
Land Rover wrote:There must be dozens of JCB 3CX's in France , there seems to be an enquiry from someone based in France regularly .
Welcome to the dark side :wave: (of the Channel....).
Tony in rural 53
Has thanked: 1295 times
Been thanked: 1111 times
Post #7 by FOWLER MAN » Thu Feb 01, 2018 9:02 pm
You will find the dowel under the seal nearest the rod end.
There should be a threaded hole in the dowel so you can use a bolt to extract it.
partsman
Real name: Graham
Been thanked: 4 times
Post #8 by partsman » Fri Feb 02, 2018 6:17 pm
only 1 possible kit for dipper ram on a 3CX of that age. Should be 60mm rod, 100mm bore.
In stock here £13
Graham
www.hydraulicplantservices.com
01342327300
Return to “Loaders/Backhoes”
