Hi guys,
got a seal gone on the dipper ram, have read up a bit on replacing and found the 'beware the gudgeon pin' pointer.
question is; were there many variations over the years for this ram? trying to locate the part number for my particular machine and having difficulties so was kinda hoping that the seal is an obvious part number for the 89 model?
any ideas?
Dipper Ram seal - 89 3cx
Topic author - Posts: 41
- Real name: nicolas
- Has thanked: 35 times
Re: Dipper Ram seal - 89 3cx
sorry, should have said, i live in france and my language skills aren't quite good enough yet to discuss something so particular so need to do my recon work online and give part numbers, guess i could ring a job dealer in uk but don't feel right about using them and not giving them the £
- Real name: Gordon Short
- Has thanked: 4 times
- Been thanked: 13 times
You should find you can search this website and find the part number required .https://parts.jcb.com/
Or call / email Vicary Plant and give them your machine serial number http://www.vicaryplant.co.uk/
There must be dozens of JCB 3CX's in France , there seems to be an enquiry from someone based in France regularly .
all sorted and in my hand, thx gents.
now to find that dwell that people speak of, can't see it at first look and nothing showing on my workshop manual, is this spigot / dowel on the smaller rams maybe?
- Real name: Tony
- Been thanked: 2 times
Land Rover wrote:There must be dozens of JCB 3CX's in France , there seems to be an enquiry from someone based in France regularly .
Welcome to the dark side (of the Channel....).
Tony in rural 53
You will find the dowel under the seal nearest the rod end.
There should be a threaded hole in the dowel so you can use a bolt to extract it.
only 1 possible kit for dipper ram on a 3CX of that age. Should be 60mm rod, 100mm bore.
In stock here £13
Graham
www.hydraulicplantservices.com
01342327300
In stock here £13
Graham
01342327300
Users browsing this forum: No registered users and 69 guests
