Hi sorry im new to this , ive just bought a 1991 mf50hx backhoe ,and im desperatly looking for a workshop manuel ,at the moment i have a problem with the steering being notchy , it seems like its low on oïl but ive checked the levels and seems to be ok ,the second problem i have is it wont drive along ,it doesant seem like the clutch is engaging ???? its strange because if i turn the the sterring sometimes the drive comes back , any advice or help would be greatly recieved
Adrian
mf50hx workshop manuel
Topic author - Posts: 2
- Real name: Adrian Beards
- Real name: David
- Has thanked: 76 times
- Been thanked: 179 times
Re: mf50hx workshop manuel
Hi and welcome to the forum, There are usually several 50HX operators manuals on Ebay, it sounds like something on your steering is effecting the drive then if it is working intermitantly could it be the transmission dump valve osr something connected to it is causing your transmission to stop engaging, i take it your digger has a 4 speed gearbox with a forward and reverse shuttle on the left hand column, that was a very good transmission alot of people still rate the 50hx against the later MF 860 machines.
- Real name: graham
- Has thanked: 97 times
- Been thanked: 74 times
look through the hatch in the floor under your feet , you will see two solenoids each side on the top of the box , most likely one of these playing up , swap the plugs when it wont move and see
Hi - one more question please
The battery with the mf 50hx is not the right one and not powerful enough to start it now its cold
Can someone please tell me what battery is the correct one, and recommend a make
Many thanks and advance
Adrian
Adrian
