Hi All, as a newbie this is my first post, so be gentle! I have just acquired a 1975 JCB 3c Mk II & one of my first jobs is to find a new door for the cab, I have looked online & most of the ones I have seen are either rotten, too dear or too far away. However, I have found a later model 3c (“W” reg ’81 I think) not very far away, would the door from that machine fit my cab or is it totally different?
I know JCB made the cab 6ins taller on the early 80’s machine, but did this affect the door dimensions? Any advice on whether this is worth pursuing? Thanks, Clayton.
JCB 3c Cab door
Topic author - Posts: 2
- Real name: Clayton Smith
Re: JCB 3c Cab door
Hi Clayton and welcome to CMN I am sure somebody on here will be able to answer your question.
- Been thanked: 684 times
Re: JCB 3c Cab door
I think you will find the door has different dimensions. The window were certainly different. I wonder if the said door is good and/or cheap whether or not it might cut down?
Re: JCB 3c Cab door
I did think that might be the case, the bloke only wants £40 for the door, I will have to check condition & have a measure up to see if a cut & shut job will be viable.
Re: JCB 3c Cab door
You could do with the actual dimensions and angles really. The windows a re taller on a 111 but did that mean that the roof is a different size to a 11 or are the angle of the corner posts different?
